What is the best subframe configuration and special frame configuration to get a balanced DL and UL throughput in LTE TDD?
Config 2 with other operator agreement.
Both should use same.
config1 provides beter Uplink Throughput.
SA2 and SSP7.
Yes but we have big difference:
Downlink about 140 Mbps
Ulink about 5 Mbps
Difference will always be there due to TDD cell and consequent DL/UL slot assignment .
Low UL THP should be rather addressed by optimizing :
Deploy UEs with higher antenna gain (Outdoor CPE - FWA ) / Indoor UEs with external antenna .
