Hi TelecomHall Experts family.
Who is the best way to move traffic from 2G->3G and don’t easy come back to 2G again?
Vendor Huawei.
(Parameters and MO, if possible)
Check 2D Event.
Thanks, I will check.
You can set like:
- Idle mode:
GSM: idle always search 3G. UMTS: rxlevmin = - 105dbm - Connected mode:
UMTS: idle mode inter-rat start search = - 110dbm, connected mode 2D = - 110 dbm. GSM rxlev about -100dbm
Adjust value of 2D, Qqualmin from 3G end and FDDQmin from 2G end
