Boda setup problem
Hello,
I have changed my PC and I have installed Boda Lite on it and database as well (it has connection to it). I am trying to parse a small E// CNAI file, but it does not do anything. The parsing works in my old PC.
Any suggestion where the problem might be?
Thanks in advance
GM
Hello @GrishManouk.
Boda is no longer supported (continued), as you can see note here: Boda Lite - Multivendor/Multitechnologies Network Management Tool (CM, PM and more) - #20 by Emmanuel
But, as the note say, you can continue to use as before.
Just one info: database is NOT needed, so you can skip all that database part - and only worry about parsing.
Now, for your issue:
  1. Didi you get the dump following recommendation → Boda - Ericsson CM Data (Dump)? (mainly the Cnaiv2 format?)
  2. Can you check the LOG, and see if any error there?
Hi Emmanuel,
Thanks for you fast reply. Looking into the log file, I found the problem. Java was not installed in the PC!
Thanks again for you support.
Cheers
Gm
