Dear All,
Did anyone got KPIs impacted due to CA link establishment failures?
As the inter-site CA performance degraded after inter-site CA link establishment failures.
Vendor is Nokia.
Dear All,
Vendor is Nokia.
Hi, Waddah.
Inter-site CA requires tight backhaul/X2 synchronization, including phase, which is not very common for FDD networks (not sure if it is your case).
The one time I tried to activate it in a single eNodeB (two separated BBUs), the alarms related to X2 poor performance were raised and no Inter-Site CA was effectively used.
Alarms raised:
Inter-Site CA link establishment failure
Inter-Site CA X2 link unavailability
Latency of the link for inter-site CA permanently exceeds threshold
So you are probably experiencing X2 issues.
Hi @marcengo
We are facing those alarms except X2 alarms. What steps we can go through and check the output
Thank you for your kind support
