Hello Guys.
Anyone know how to calculate 3G Max Cell power.
By summing all channels? (including Physical and common channels?)
Or anyone has a “calculator”?
Hello Guys.
You can check Max Tx Power.
If you are referring to maximum transmitting power of any cell then check MAXPWR.
If you are referring to maximum PCPICH power then you have to see the specific channel power, because rest of the control channels powers set by giving offset to that power.
The cell max power depends on the RU power.
For example if you have a 60W RU with 3 cells configured at 20W. Then your maxCellPower is 43dBm.
check parameter: maxDlPowerCapability ( get . maxdlpower )
It is automatically calculted based on RU capability and configuration
