Hi All,
I have attached the following scenarios in the picture, about how the neighbour cell interference is considered for the RSSI.
Could you please help with your comments/corrections?
Will be really helpful
Thanks
~p
Hi All,
Thanks
~p
RSSI calculation in simulated environment in c++ | 0 | 439 | March 26, 2023 | |
How to monitor environmental interference in LTE from overshooting cells? | 2 | 459 | November 29, 2022 | |
NR throughput calculation for LTE-NR coexistence using dynamic spectrum sharing | 1 | 645 | July 17, 2020 | |
How to find UL interference in LTE-NR scenario? | 0 | 572 | September 14, 2021 | |
4G Interference matrix | 0 | 627 | August 13, 2020 | |
Minimum RSRP between Serving and Neighbor cell to avoid SINR degradation | 3 | 528 | September 8, 2021 | |
5G cells with the same PSS ID | 1 | 492 | October 12, 2022 | |
5G Reference Signal Power Calculation | 2 | 4027 | March 2, 2022 | |
5G cell capacity or spectrum efficiency calculation | 2 | 1191 | July 6, 2021 | |
LTE mod 3 vs and mod 30 | 1 | 1694 | October 27, 2022 |
