Can any one suggest LTE high cap sites parameters in Huawei 3900 in order to increase user thpt.
What is the parameter name in Huawei as in Ericsson as Crsgain,pdcchtypeBgai,pdcchpowerBoost Max?
There are a lot of things to try to improve that.
Can you please guide me through some of the hicap settings in Huawei 3900?
Will it help Changing the scheduling algorithm from EPF to max C/I for high PRB utilisation case with lower user thpt…
To improve you can upgrade bandwidth 5, 10, 15 or 20 MHz
Any hicap parameter settings…pls suggest
Dear all,im facing the same issue.hope someone can throw some light. Thanks
