In a scenario where two operators are sharing the same RAN infrastructure with basically all the same parameters and configurations (same bandwidth, same frequency band, same carrier aggregation config same QCIs, etc), can a different value of APN-AMBR (in one case we have more than 4Gbps and on the other we have 256Mbps) be the reason why we have a considerable difference of throughput?
Hainm
2
APN-AMBR is stored in HSS to indicate max bit rate of all non-GBR bearers on that APN.
For one APN, UE may have 1 default bearer and many dedicated bearers.
The APN-AMBR is sent from MME to gnb in “initial context setup request” which limit rate of UE connected to the specific APN, so in this case it may be the reason of major difference in DL throughput.
Related Topics
What is relation between user throughput and APN-AMBR? | 6 | 922 | May 27, 2023 | |
5G QoS - MFBR/GFBR
0 | 12 | October 28, 2024 | |
For Uplink bearer filter and Downlink bearer filter, can it be same QoS precedence rule? | 3 | 271 | May 30, 2023 | |
Data speed of one carrier too slow compared to other carrier | 2 | 354 | September 20, 2023 | |
Overall Cell Throughput of single UE is lower than of 2 UEs | 2 | 414 | December 30, 2021 | |
nomPDSCH-RS-EPRE-Offset | 0 | 1595 | April 28, 2021 | |
Can we change HARQ settings and what does it depend on? | 1 | 577 | January 18, 2022 | |
Uplink Throughput comparison | 2 | 419 | September 27, 2022 | |
Counters in 5G for GBR bearers (VoNR for example) released when QoS cannot be fulfilled | 4 | 788 | March 13, 2021 | |
Backhauling Bandwidth for 4G/5G Mobile RAN | 0 | 329 | September 18, 2023 |
