Can I set the same gNB as SA and NSA mode?
To support both SA user and NSA user at the same time?
Yes, you can.
Hi,
I didn’t know there are separate SA and NSA devices. I thought every 5G capable handset could use SA. And if you can use SA why would you want to switch to inferior NSA?
NSA is not necessarily inferior
in which aspects is NSA better?
For example in network setup which has SA NR34 + NR9/NR21 CA?
