Can PUSCH be transmitted in an RB with different level of modulation?
For example few PUSCH REs are BPSK and the of the REs are QPSK.
No, that’s why its called single carrier FDMA.
That single carrier denotes same modulation.
Can UE transmit PUCCH in same slot as PUSCH? | 1 | 1071 | June 29, 2022 | |
What type of modulation is used for PUCCH? | 20 | 1158 | April 1, 2022 | |
LTE UL queries | 1 | 551 | January 21, 2020 | |
Can PUSCH be used for CQI report only or PUSCH is for both CQI + UL data? | 5 | 1140 | July 15, 2021 | |
How will UE know that PDSCH feedback need to be sent on PUCCH or PUSCH? | 1 | 397 | March 29, 2022 | |
Are RACH occasions reserved for RACH or can they be used for other PUSCH transmissions? | 1 | 398 | June 4, 2022 | |
Is PUSCH and UCI and encoded separately in 5G Uplink? | 1 | 1010 | April 27, 2022 | |
Will UE Transmit the scheduling request (SR) for every PUSCH? | 8 | 846 | April 12, 2022 | |
UCI over PUCCH or PUSCH? | 2 | 1903 | March 4, 2023 | |
5G PUSCH resource allocation at gNB for multiple UEs in Random Access procedure | 1 | 508 | June 28, 2023 |
