Can SA capable UE configure to ENDC in NSA cell?
Fr example: if i have TDD layer with 100 MHz-NSA and FDD band with 20 MHz SA.
So if I want to use TDD-100 MHz for SA UE in NSA cell, is it possible?
Can same cell in 5G be used both as NSA and SA? | 2 | 480 | November 1, 2023 | |
Deploy SA and NSA sites in same cluster | 9 | 1110 | March 7, 2021 | |
NSA Measurement Gap Configuration for B1-NR | 0 | 1024 | October 6, 2020 | |
5G NSA UEs outperforming 5G SA UEs | 4 | 678 | October 20, 2022 | |
UE ENDC capable dont connect//establish split bearer to 5G NSA network | 0 | 11 | October 18, 2024 | |
Do any devices support TDD + TDD UL CA in 5G NR SA? | 4 | 14 | December 6, 2024 | |
Can I set the same gNB as SA and NSA mode? | 4 | 562 | December 14, 2022 | |
UL 2CC CA in 5G NSA | 1 | 339 | October 5, 2024 | |
Is there any restriction to deploy NSA 5G using TDD? | 1 | 430 | March 15, 2021 | |
In NSA, is idle mode UE connected with 5G? | 6 | 2309 | July 8, 2022 |
