Can the LTE Band used for DSS be aggregated?
Hello,
Can a mobile aggregate an LTE cell which is using as 5G DSS?
an example, a mobile is on 1800, and 2100 band is used for DSS, so if the mobile uses the 2100 as Scell for LTE carrier aggregation, can it use the same 2100 to establish the 5G leg,
In the opposite way, if the mobile has the NR leg established on that band, can it make aggregation with its LTE along with the 5G leg.
No not allowed by 3gpp for most bands
