Hi Ericsson.
Can we select multiple sites and get MO details in AMOS?
Hi Ericsson.
You can do it with cmedit.
Also via mobatch, you can do whatever you want on any number of sites.
Hello,
Yes u can do it with mobatch on ENM (scripting or amos VM) or with CLI (using cmedit)
Alternativly on moshell
Respects
amos -m rbs1,rbs2
Hi, it doesn’t work with bb66xx?
BaseBand node need to turn on onap interface on each node, then can do operation like “amos -m”
Thanks
