Can we send more than one DCI in the PDCCH, like DCI format 1_x and DCI format 2_x?
This should be allowed with two candidates in an aggregation level.
As per my understanding.
I think this is not the case of a single PDCCH for a UE.
I meant to ask for a single PDCCH for a UE.
In a single PDCCH resources only.
That’s what aggregation levels candidates should define… How many DCI can be packed in this PDCCH.
No, I think this is not what ALs define!
ALs are (as per my understanding) are the copies of same PDCCH scrambled with same RNTI for UEs to decode any one of them in case channel condition is bad.
My understanding is those candidates can also accommodate diff DCIs and not just copies of the first one.
downlinkchannelbw-perscs… does anybody has a understanding how it helps in dedicated mode?
