Inter freq failure happened 100% .
Which are reports command to see the cause of failure?
Vendor is Ericsson.
Vendor is Ericsson.
For Ericsson it should be counters, I think.
They don’t have reports number like Nokia.
Execution or Preparation?
Go and check stats per relation to drill down the issue.
Preparation.
Check for the discrepancies, TAC, eNodeBID, MME definitions.
The failures you are facing are on the same site or different sites?
What are the performance of your S1/X2 of the affected eNb?
