CBRS integration
Does anyone here have experience on CBRS integration?
Vendor is Ericsson
CBRS is just a band, no?
What do you mean by integration?
My bad - yes CBRS is freq band.
The thing is we are planning to use that for Fixed Wireless.
So the way it will be integrate to ericsson ENM would be same as the FDD LTE integration?
That’s what I meant to say Integration. Meaning create a site in ENM then integrate it with the corresponding site.
There is also the SAS integration
You need to work with a SAS vendor say Google, get your CPI license and integrate the radio over SAS API.
Is this what you mean?
