Hello experts
Does anyone have any idea regarding the CCE DL Allocation failers in LTE, the vendor is Huawei.
the Avg thr and PRB are within acceptable range.
Hello experts
UL/DL CCE Allocation Failure Caused by Lack of Resources and by Power Shortage | 5 | 1146 | November 29, 2022 | |
Reduce CCE Failure Rate in low users/low utilized cells (LTE) | 5 | 1874 | March 8, 2021 | |
Control rate of UL CCE | 36 | 3694 | August 22, 2022 | |
PRB utilization stuck around 90% and not able to reach 99% | 6 | 797 | July 4, 2021 | |
Zero numbers of Load base HO b/w Layer cause imbalanced PRB | 2 | 173 | June 11, 2024 | |
Low Payload and DL PRB utilization but still Low Throughput | 5 | 1395 | November 9, 2023 | |
Throughput and Abnormal MME fails in LTE | 3 | 1104 | March 13, 2020 | |
Parameters setting suggestion for HO/Load Balance in High PRB Utilization/Low DL Throughput scenario | 4 | 1584 | October 12, 2020 | |
PS and CS CE congestion increased, but no increase in traffic | 7 | 892 | November 9, 2021 | |
LTE UL sync failures increased after RAN upgrade | 14 | 731 | August 6, 2021 |
