C = colorless
Colorless wavelength means Tunable
Colorless wavelength add drop ports allow re-configuring ROADM remotely
That can be done when transponder or line board have been installed in the rack
Colorless means that any carrier / wavelength can be added or dropped from any port on roadm
Colored means the Mux and demux ports allow add and drop specific wavelength
Colorless scenario used efficiently with ASON where we use tunable Transponders
In this case we can flexibly tune wavelengths and perform rerouting to avoid wavelength congestion and protect network against route failure
D = directionless
Directionless means the wavelength carrying traffic can be transmitted to any direction
Directioned means that the traffic will be transmitted to specific direction
In that case a site visit required when we need to change the path of Traffic to adjust the fiber cabling
Used with ason to dynamically detect paths and create optical cross connections
ASON : automatic switching optical network
- ASON is a high level of optical networking routes mangment and protection allowing for network protection against multiple failures with different types of SLAs
Linkedin:
