Cell configured with 50 MHz BW with 1 or more SSBs in NR SA
Has anyone seen up to now cell configured with 50 MHz BW with 1 or more SSBs in NR SA?
(Not in NSA 5G NR)
Thanks.
SSB beams depends mostly on MIMO and frame structure.
We can configure more then 1.
What is your frequency range is it < 3 or > 3 GHz to 6 GHz.
Cell BW will define number of PRB. Did not find any link with SSB beams.
SSB comprises PSS+SSS+MIB, so for primary access, SSB should be configured.
@Ryan , perhaps you are confusing SSB with something else.
Hello,
Currently, most of the 5G SA is done in low band with very low bandwidth such as 10MHz, however the configuration you mentioned is Ok and can be used with no problem, unless you have a specific problem :wink:
