Does anyone use this tool?
Cellular Pro
Yes, i do.
Any comments about it?
Hello,
Yes, I use it and got a basic license a while ago.
It’s creator has a Telegram group which you can join here:
It supports dualsim, and band locking amongst other features.
It has some free features, then for advanced stuff you have a monthly/yearly fee, just like Network Signal Guru.
Price varies depending on the stuff you use. I don’t need logging or mapping, just realtime cell monitoring, so I haven’t tested it deeply.
Usually I disable my second SIM for the tests, so it doesn’t interfere with my tests.
