Changing maxDlPowerCapability on NodeB
Hello i am having issues on changing maxdlpower on NodeB to match the one on the RNC. This is the feedback below
1527 RbsLocalCell=S1C1 448 !!! Processing failure :se.ericsson.cello.moframework.NoSuchAttributeException
TAG :“NoSuchAttribute” VARIABLES :“$attrName” = “maxDlPowerCapability”, “$moTypeName” = “RbsLocalCell”
Hi, @King, maxDlPowerCapability is read-only attribute. To change power on CPP configure maxTotalOutputPower on TpaDevice and NodeBSectorCarrier configuredMaxTxPower on BB
it is a DUW not BB. maxTotalOutputPower is already configured to the desired power . How do i get MaxTxPower on the DUW ?
Set the same value on RNC. For example for RRUS 01 set TpaDevice=1 maxTotalOutputPower 20, then on RNC UtranCell power to 420. Same power on RRUS 12 is TpaDevice 1 and 2 - both to 10. Or I don’t get you.
I am a little bit confused.on my network there is no BB we use a DUW. There is TpaDevice which i have set the MaxTotalOutputPower but i don’t have NodeBSectorCarrier
NodeBSectorCarrier is on BB nodes only.
DUW:
TpaDevice maxTotalOutputPower
BaseBand:
maxTotalOututPower has been set to 60 but maxDlpowerCapacity is 418 on the nodeB but on the RNC is 448.I want the value on the nodeB to match the RNC
What type of RRU? How may branches are configured? (get sector numberoftx) How many carriers in the sector? Is RRU shared for LTE-2100?
RRU TYPE :RRU2219B1
NumberTXBranches:1
NumberofCarriers:4
RRU is not shared
So you use only one branch which is 60Watts (Radio 2219 is 60x2 total power). 60/4 carriers is 15Watts which is 41.8 dBm. You have two options: first, to configure second branch and distribute two carries there and increase power to 30 Watts per carrier. And second: set power to 418 from RNC side. Also, maxDlPowerCapability may depend on configured attenuation.
thanks i will go with the first option,is there a command that can be used to add the additional branch or i have to reintegrate the node B ?
@King you need to unInitSector, set Sector numberOfTxBranches to 2, set maxTotalOutputPower on TpaDevice=1 and TpaDevice=2 to 60, then InitSector with arguments 2, 1. I believe, this should be enough. You may need to make sure the physical connections are correct.
yh it is enough but there is another problem.the site was integrated with the wrong RBB.instead of RBB22_1B it was integrated using RBB12_1A.
Is there way to correct the radio building block without integration ?
Yes, you can change it while sector is in uninit state.
thanks it worked
