Check BW capability of Radio Units
Greetings dears.
I have seen these Radios before:
Radio2238B8B20B28B
Radio227922B822B20C
How to check BW capability of these Radios in Ericsson?
It shows the band number, not BW.
It depends on model.
Usually LTE FDD has 4-5 carriers (20 MHz) per band and based on power amp.
2x80w or 4x40w then 1800 to be config based on power.
Thank you. I know, but I need to make sure.
There is two things important for Radio Units:
IBW and OBW
I am searching these two factor for these Radios.
This you sould get from specific market solution person.
b3 will have 40-45 IBW if more than that 1 addl carrier to be defined.
Best to have harmonise across operator.
Thanks, but this is B20/B28, not B3.
B20/28 should vary based on region.
Apac will have 30-40.
If it in USA would be 10-20 since it’s fragmented between operators.
b20-800 will have similar. 20-30 IBW.
