Hi All,
How do I check encryption mode in 4G?
Vendor is Huawei.
Uu interface?
S1 interface.
I think you are looking for cypering algorithm, use LST EUEPCSEC
command.
Thanks
But I’ve found this command also and the results aren’t the same with the command you mentioned
LST ENODEBCIPHERCAP
Yes, you have to use ENodeb Cipher capability (ENODEBCIPERCAP) MO to configure it as above MO which I mentioned will available with an another optional feature activation only.
Many thanks dear.
