Check UE support to any Band Combination
If i want to check UE supports a en-dc band combination, i.e.: LTE band2 + NR band 260 (100 MHz) + NR band 260 (100 MHz).
In UE capability info can see LTE band2+ LTE band12 + band30 + band66 + NR2600
Does it mean the above combination supported?
Check on cacombos.com.
Does any UE support EN-DC intra-band such as b3-n3?
You can check it at http://cacombos.com/
I checked some UE, just find huawei mate 40.
Maybe very few UE supporting.
There are combinations with B3, n3 and other bands, at least for Samsung S23.
Usually high tier devices supports.
Yes, b3+n3 & other bands such as 2600/3500.
But only b3+n3, I think very few.
How can I find which phones supporting this band combination for LTE: 1-3-3-8-20
