Hi Guys,
Is there any way to check specific UE’s context information on gNB (E//, Huawei, Nokia)?
Regards,
Laxmikant
Hi Guys,
Regards,
Laxmikant
Guide to Checking N71 (600 MHz) 5G Band Supported UE Details | 7 | 22 | November 18, 2024 | |
When DU receives UE Context Setup Request message from gNB-CU, what next step it does? | 1 | 418 | May 1, 2023 | |
eNB sending sgNB release request with cause radionetwork: unspecified | 0 | 961 | November 29, 2022 | |
How does gNB indicate session AMBR to UE? | 8 | 39 | September 25, 2024 | |
How to find HPLMN within frequency scanning of 5G NSA network? | 3 | 384 | May 25, 2023 | |
Check if user selected 4G as Preferable Network (instead of 5G)? | 2 | 411 | April 25, 2021 | |
How to check whether UE triggered HO or not | 0 | 431 | April 29, 2021 | |
Measurements for NSA DC UE Mobility Cases | 0 | 556 | October 7, 2020 | |
Why does gNB need IE NeedforGapsInfoNR from the UE? | 0 | 243 | March 22, 2024 | |
UE capability info for eutra, nr, eutra-nr | 3 | 608 | November 21, 2021 |
