Hi All,
Can somebody give command to check RET from RRU as to check in which carrier and cells it is configured?
Vendor is Huawei.
DSP RETSUBUNIT
command.
But carrier and cells, from RRU?
Ret gives subunit and device…
What to know device and subunit from RRU?
I believe it will be either DSP RET
or DSP RETPORT
One of those should show subrack/slot.
Then you match those subrack/slot from Device Maintenance or DSP RRU
Command LST RRU
Yes, LST RRU
Thanks guys, I’ll check all commands.
