If LAN down alarm raised: please check the Ethernet Interface and Ethernet cable, port, card.
If RCC alarm raised: please check the if cable connectivity from RAU side and from modem side and check the of connector.
If radio ID mismatch alarm raised: please check the Modem ID for nearend and farend and ensure the IDs is as per plan.
If HCC alarm raised: please check the MMU in both sides.
If far end no contact alarm raised: please ensure the configuration has the correct frequency, ensure both ends use the same channel spacing and same RSEC, check the power value.
Troubleshooting methods for the microwave Link :
Warm restart
Cold restart
If loop
RF loop
Software upgrade or downgrade
Hardware replacement
Iinterference test
LinkedIn:
