Hello Masters, has anyone ever come across a communication failure between enodeB and Nokia’s BTS Mediator, even if the IP connectivity is ok between them?
Related Topics
Interference issue between 2G/3G and 4G Basebands during fiber connection | 1 | 10 | October 19, 2024 | |
INIT message is sent from eNB and ABORT comes from gNB | 2 | 1143 | May 9, 2022 | |
Inter-Vendor HO Failure in LTE: Nokia to Huawei Post Band B66 Addition
6 | 15 | September 9, 2024 | |
Troubleshooting ENDC setup failures | 4 | 2506 | February 25, 2022 | |
B1 Measurement config after Blind Leg Addition | 0 | 426 | January 27, 2023 | |
EVS dropped to AMR-NB only on my side | 0 | 37 | September 8, 2024 | |
E-UTRAN New Radio - Dual Connectivity (EN-DC) across different vendors | 0 | 238 | March 5, 2024 | |
UE ENDC capable dont connect//establish split bearer to 5G NSA network | 0 | 11 | October 18, 2024 | |
Inter-vendor compatibility for 5G SCG and 4G MCG [Nokia and Huawei] | 0 | 34 | August 12, 2024 | |
4G TDD interference due to GPS sync issues | 3 | 1970 | October 5, 2021 |
