Any good methods to compare two eNodeB parameters (something like MML compare)?
Use beyond compare tool.
Huawei FMA compare, from NE Backup.
What tool is that?
Beyond Compare is a tool that allows you to quickly and easily compare your files and folders.
By using simple, powerful commands you can focus on the differences you’re interested in and ignore those you’re not.
You can then merge the changes, synchronize your files, and generate reports for your records.
Note: tool requires a license (paid, ~ US $ 60,00)
With Notepad++ you can compare 2 XML files!
And it’s free: Notepad++ Free Editor
With Ultracompare is much better.
But also requires license / paid.
I am looking for Huawei like comparison in Ericsson. Surely there must be a way to compare parameters between two sites.
Can anyone please assist me in this.
!For Ericsson
!Connect to two base stations
moshell -m xx.xx.xx.xx,xxx.xxx.xxx.xxx
!Get list proxy address
pr eUtranCellFdd=
!Get difference for two objects use proxy address
diff 1234,2345
Can you please explain it by writing down the commands with examples.
How do I enter two eNB or gNB together and what commands are next. Thank you
