Compare UE DL Throughput for different vendors
I’m trying to compare UE DL Throughput for two different vendors.
But I’m not sure is it possible correctly because the formulas are different.
For example:
  • One vendor calculating based on PDCP Volume and subtract the last TTI
  • Other vendor is calculating based on IP DRB Volume/IP time
    Anyone had similar experience?
Why cannot you use same formulae?
Not available currently.
Second vendor has lower throughput but must take somehow in consideration difference in formulas I guess.
2 different formulae is almost impossible to compare.
Even the same formula changing the last TTI term changes every thing.
Good luck with that. :wink:
I think IP throughput is used by Nokia, they have another formula to exclude last tti. Please check with them for better comparison
