Hi Guys,
Does someone knows any counter to check if CA is happening?
Vendor is Ericsson.
Hi Guys,
Vendor is Ericsson.
pmCaActivatedDlSum, pmCaActivatedDlFddTddSum, pmPdcpVolDlDrbCa, pmCaScheduledUlSum are some of them.
Note: Some counters depend on OSS version/corresponding features activated or not.
Mo Class = Lrat.EUtranCellFDD
Pm Counter = pmCa*
Like pmCaActDlIeeNBSum, pmCaActivateDlFddTddSum…
Are all those pmCA* counters available to TDD?
Yes, they are.
you can see cell level volume for scell pmRadioThpvolDlSCell
TDD cells - PMCAACTIVATEDDLFDDTDDSUM could work as well
hi dears
would you please help me for active CA on node?
thanks
Start Time: 2024-01-03 12:45:00 End Time: 2024-01-03 13:30:00
Object pmRadioThpVolDlSCell pmRadioThpVolDlSCellExt
EUtranCellFDD=LE2884XA0 0 0
EUtranCellFDD=LE2884XA1 0 0
EUtranCellFDD=LE2884XB0 0 0
Sorry, I did not understand what you want.
i want to how to active CA on node
EUtranCellFDD=LE2884XA0 ? ?
EUtranCellFDD=LE2884XA1 ? ?
EUtranCellFDD=LE2884XB0 ? ?
Do you want to know how to activate CA in one cell?
The commands used to activate, is it?
exactly
Never tried activating CA only in one cell.
CarrierAggregation feature must be activated in license.
Also check ENodeBFunction=1,CarrierAggregationFunction is created and its attributes set properly.
Last but not least, set sCellCandidate = 1 in those EutranCellRelation
For a 4G cell:
pmCaActivatedDlSum is primary CA
pmRadioThpVolDlSCell is secondary CA
Don’t know what pmRadioThpVolDlSCellExt is ??
