Hello,
In Huawei TDD_LTE, keep all other parameter fixed just changed the CRS Port number.
Coverage seems to be reduced.
Any idea why?
Power per port gets reduced.
Csi-rs ports are 3000s.
How exactly did you change them?
But MaxTxPower per Cell remains same.
Is there anyway to offset this drop in coverage?
Maybe with some boost in RS power?
Pdcchmaxcoderate value.
Check if you enable the Tx beamforming. If not, although the total cell tax power is same as before, multiple tx ports not only can’t bring any diversity gain, but may cause adverse random beamforming effects.
LTE coverage is measured by CRS power.
Cell power = channel_tx_power * no_of_port
Cell power also control by no of 20W power license bought.
So, if license total unchanged, no of ports increaed 2 times, RS power must be reduced 3db. So that, power per tx channel also reduced 2 times, ports increaed 2 times and total power the same as before.
HI,
Will Power get reduced if CRS Port =2 and Physical Antenna port=4.
RRH Power=20 Watt
Number of Physical Antenna Port=4
CRS Port=2
So Power Per Port will=10W or 20 W .
Thanks
