Hi Dears.
Anybody know how can I create XML for Nokia LTE for parameters change?
Hi Dears.
There used to be an Excel macro.
Nokia XML used something called RAML convention.
But basically it is XML file.
What is your sw version? Is it sran?
You can either use an Excel Macro or Nokia tool “Plan Editor”.
iirc, Plan Editor needs license.
Also, tried to work with plan editor once but i think there is a learning curve.
Just my own thought.
L19 SRAN.
Thanks a lot, I made macro for this.
