Decode the Ericsson Cell Trace binary file (generated with ENM)
Hi Everyone.
I would like to decode the Ericsson Cell Trace binary file (generated with ENM) and save the parameters of some EVENTS as a CSV file.
Which tool can do it?
I know E// have tool ltedecoder…
What’s the format of the file? XML?
Format is asn1.
Can you share sample?
This tool is included in ENM
Can you explain please how to generate such trace from ENM and how to parse it through ENM parser as well?
  1. Go to Ericsson Network Manager -> PM Initiation and Collection (Create Subsciption)-> Cell Trace / EBS-L Subscription
  2. Fill in required data
  3. After trace will finished connect to Scripting VM with ssh and decode files lteCellTraceFileDecoder /ericsson/pmic2/CELLTRACE/pathtofile
