Hello All,
Do you know how can we decrease IFHO PS Failure in 3G?
Which parameter can be optimized?
Vendor is Nokia.
Walty95
1
- If both layers are continuous: configure same sector inter freq cells only .
- Check the thresholds for HO and compressed mode enter/exist in FMCS/FMCI families.
- Check the reason if failures wether it is alarms, resource cong, or radio and resolve accordingly.
Related Topics
How to improve the Throughput in 3g? | 16 | 3975 | August 28, 2018 | |
Reduce CCE Failure Rate in low users/low utilized cells (LTE) | 5 | 1886 | March 8, 2021 | |
Reduce Number of Paging Messages Lost due to PCH Congestion | 5 | 1925 | February 4, 2020 | |
Need parameters to optimize poor cssr, poor HOSR,, high DCR | 6 | 2687 | August 8, 2022 | |
Solution for 3G RRC call setup failure (cause admission control) | 6 | 2177 | April 29, 2021 | |
Packet call setup fail due to bts for interactive | 1 | 141 | July 11, 2024 | |
Improve 3G KPI with parameters | 5 | 853 | August 28, 2023 | |
CS Core 2G & 3G Paging success rate | 2 | 1762 | September 27, 2023 | |
How make HO easier or harder in Nokia in dedicated mode? | 5 | 2032 | October 4, 2017 | |
Restricting interference through parameter optimisation | 4 | 363 | June 23, 2023 |
