I have an old problem on my network 3g Nokia, as in high loaded sites and hotespot, rtwp is very degraded and remaining kpi are fine. From end user si de no body can access to network. Please advice.
Stanis
2
You can try the following:
1 - Disable 2ms TTI HSUPA,Change CQIFeedbackcycle to 6 or 8ms
2- You can change the RACH parameters to reduce access power. SIR adjustment may also help to reduce the RTWP
Thx. We have used meh and tunned rach paramètres and no 2ms tti but problem still not resolved. Rtwp is degrading from -100 to -80 dbm
Related Topics
Call setup degradation on UMTS site | 4 | 812 | October 7, 2021 | |
Solution for high RTWP | 2 | 1333 | December 14, 2021 | |
Please suggest parameters I can use to control the RTWP | 7 | 2762 | January 14, 2019 | |
Improve 3G KPI with parameters | 5 | 849 | August 28, 2023 | |
Huawei 4G low RACH SR with huge attempts/fails L.RA.GrpA.Att/L.RA.GrpB.Att | 0 | 279 | December 21, 2023 | |
Jitter and Latency issues | 2 | 793 | June 5, 2024 | |
How to improve the Throughput in 3g? | 16 | 3974 | August 28, 2018 | |
Offloading 3g traffic to 4g | 3 | 121 | July 18, 2024 | |
Multiple cells suffering from degradation of LTE INTRA-RAT HO | 5 | 445 | March 28, 2021 | |
Parameters to reduce VoLTE audio gap | 17 | 4250 | November 26, 2021 |
