We’re tired of hearing that Wi-Fi operating at 5.0GHz is faster than 2.4GHz, aren’t we?
We’ve heard it so often that most people accept it as truth, often dismissing the use of 2.4GHz or thinking the connection is “bad” if it operates on that frequency.
But let’s look at the facts:
When using a 20 MHz channel width, both 2.4 GHz and 5 GHz bands can achieve the SAME maximum data rates for a given Modulation and Coding Scheme (MCS) index under ideal conditions (i.e., no interference and optimal signal quality).
The MCS index table defines data rates based on various factors such as the type of modulation (e.g., QPSK, 16-QAM, 64-QAM), coding rate, and the number of spatial streams. These factors are the same regardless of whether you’re operating in the 2.4 GHz or 5 GHz band.
The maximum data rate is lower with a 20 MHz channel compared to wider aggregated channels (40 MHz, 80 MHz, etc.), but the achievable rates are the same for both 2.4 GHz and 5 GHz for the same MCS index.
In reality, the main limitation of the 2.4 GHz band is the reduced number of available channels. Practically, it’s only possible to operate with a 20 MHz width on 3 non-overlapping channels, which prevents channel aggregation. In contrast, the 5 GHz band, due to the greater number of available channels, allows the combination of multiple 20 MHz channels to increase bandwidth.
Examples of Data Rates:
- If we are using a single spatial stream (1x1 MIMO) with MCS index 7, we get 64-QAM modulation with 5/6 coding, which can achieve a theoretical maximum rate of 72.2 Mbps for a 20 MHz channel —> on both 2.4 GHz and 5 GHz.
The 2.4GHz band is not “bad” or “obsolete” at all, as it remains strong in Wi-Fi 7!
What factors should we consider then?
- Although the theoretical rates are the same, the 2.4 GHz band is more susceptible to interference due to the larger number of devices operating on that band (e.g., Bluetooth, microwaves, etc.). In some real-world scenarios, this could result in lower effective data rates on 2.4 GHz compared to 5 GHz.
- Range and Penetration: The 2.4 GHz band generally offers better range and penetration through walls, while the 5 GHz band provides better performance at shorter distances with less interference. This means that in some environments, the 2.4 GHz band may perform better due to better signal strength despite potentially higher interference. Practical examples include industrial areas or warehouses, where coverage is prioritized.
So, before dismissing 2.4GHz from your Wi-Fi project, understand that there are indeed applications and advantages to using it. It’s all about knowing where and how, and even combining both bands to get the most out of your investment!
Source (in Portuguese):
