Hi Guys,
Is there a way to, via drive tests, indentify if active sharing between two MNOs is taking place at a Site in 5GNR?
In case of sharing via National Roaming or MOCN, UEs with SIM cards from two sharing MNOs would be using the same spectrum ( and Cell IDs) so that should be straight forward. I assume?
However, is there also a way to detect sharing in the case of different frequency bands are used ( e.g.MORAN) through drive tests?
