Can anyone suggest if there’s any software in a 3G network that can detect duplicate Primary Scrambling Codes (PSCs)?
I mean, if the same PSC is used, it could cause issues. Any suggestions to avoid this?
If you have access to Huawei’s tools, OMStar or U-Net would be your best options.
However, with a bit of Python scripting, QGIS can also handle this.
Are there any vendors other than Huawei?
The choice of vendor doesn’t really matter; however, another option to consider is Planet, which is owned by Infovista.
I mean, can we check using Omstar and U-Net?
Do you mean Invovisa from TEMS?
UE log?
No, it’s a separate software specifically designed for Planning.
I’m sharing some helpful training materials on using QGIS for PSC and PCI checks:
#PSC QGIS.rar (20.3 MB)
After importing the relevant data, you can get a clear visualization of PSC/PCI.
Clicking on a sector highlights any conflicts in other sectors.
Of course: For those with access to OMStar or GENNEX Cloud, you know there’s no need to go through all this.
