Hello Experts,
Could you please explain the difference between offsetToCarrier and offsetToPointA? Both look quite similar to me, would appreciate if someone can explain the difference.
Thanks.
Hello Experts,
Thanks.
Offsettocarrier is the offset from absolutefrequrncypointA.
When offsetcarrier is Non-zero value then CRB will start from offsettocarrier.
Hi, Hope this will make you more clear.
offsetToCarrier : Offset in frequency domain between Point A (lowest subcarrier of common RB 0) and the lowest usable subcarrier on this carrier in number of PRBs (using the subcarrierSpacing defined for this carrier).
offsetToPointA : The offset in PRB between the Point A and the lowest subcarrier of the lowest PRB of the cell-defining SSB after floating SSB is resolved.
absoluteFrequencyPointA : Absolute frequency position of the reference resource block (Common RB 0). Its lowest subcarrier is also known as Point A.
For more details 5G | ShareTechnote
