Do we have default bearers in 5G SA case?
Nsa there should be!
We’ve got default QoS Flow rather than default bearer which is used in NSA.
Same as PDN connection that we have default bearer.
For PDU Session also we have default QoS Flow.
QCI for Default Bearer | 6 | 2331 | November 26, 2020 | |
Can I set the same gNB as SA and NSA mode? | 4 | 560 | December 14, 2022 | |
5G SCF for SA and NSA | 0 | 549 | June 10, 2020 | |
Has anyone seen a 5G DSS SA network? | 4 | 897 | September 30, 2022 | |
Counters in 5G for GBR bearers (VoNR for example) released when QoS cannot be fulfilled | 4 | 788 | March 13, 2021 | |
5G SA Call Flow and Wireshark Parameters | 0 | 62 | September 26, 2024 | |
Problems with split bearer 5G NSA | 3 | 827 | September 13, 2022 | |
How can we have 3 PDU per UE in SA network with different QFI? | 3 | 65 | July 29, 2024 | |
For Uplink bearer filter and Downlink bearer filter, can it be same QoS precedence rule? | 3 | 271 | May 30, 2023 | |
Can we establish a DRB without corresponding PDU session? | 5 | 615 | March 21, 2021 |
