Does high sub carrier reduces fading in mm compared to low subcarrier used?
What is logic behind this is it because of more time slot division in ofdm?
But the coverage too will shrink, in high subcarrier.
Related Topics
Why there is more subcarriers in Downlink than Uplink? | 3 | 761 | October 30, 2021 | |
Lower latency in 4G/5G than in 2G/3G | 3 | 789 | April 6, 2020 | |
Any network in NR using 15 kHz sub carrier spacing globally? | 4 | 422 | June 7, 2021 | |
Does Uplink FSS improve Throughput and CQI? | 2 | 447 | April 6, 2022 | |
How DFT-s-OFDM helps in reducing PAPR (Peak to Average Power Ratio)? | 0 | 817 | July 28, 2021 | |
Resource block latency impact | 1 | 463 | June 21, 2021 | |
DC subcarrier in LTE-UL, LTE-DL and NR | 0 | 2193 | October 21, 2022 | |
4T4R more PHICH and less PDCCH in slot zero of subframe as compared to 2T2R | 0 | 438 | July 1, 2020 | |
Is the pathloss larger at mmWave frequencies? | 0 | 468 | October 21, 2021 | |
Periodic vs A-Periodic SRS in sub 6 GHz and mmWave | 0 | 355 | May 6, 2023 |
