Does IMS allow VoLTE calls setup on default bearer?
Dear Experts.
For example when PCRF is faulty, bypass PCRF, no dedicated bearer.
For emergency, it is ok, accept voice quality down. But is it ok VoLTE calls on default bearer?
I’ve heard Huawei IMS can do this…
Yes volte can be done on default bearer.
On your P-CSCF you can set if dedicated bearers are required or not.
Some networks are deployed without dedicated bearers for VoLTE but most commercial modems (Qualcomm / MTK / Unisoc) require a dedicated bearer to be setup within ~10s or the call will drop citing “Precondition not met” or similar.
