Hi guys,
Does network perform the CRC check on the UCI?
Any thoughy on this?
5GChacha
2
It depends on the PUCCH formats some formats have CRC and some don’t.
I guess format 0 and format 1 doesn’t have since they carry max 2 bits.
Related Topics
Is there any rate matching of PUSCH around PUCCH formats in NR? | 0 | 412 | March 13, 2021 | |
UE not sending ACK PUCCH Format 1A for MSG4 | 0 | 291 | January 5, 2024 | |
VoLTE ROHC issues | 0 | 516 | December 16, 2021 | |
What is PUCCH format selection criteria? | 0 | 399 | July 4, 2022 | |
Is frequency hopping always enabled for PUCCH Format-0? | 1 | 293 | January 1, 2023 | |
For UL CA in LTE for 2 CC is there any requirement for data split at mac layer? | 7 | 510 | August 25, 2021 | |
Can same information be transmitted in PUSCH than PUCCH? | 1 | 283 | September 13, 2023 | |
LTE PUCCH Resource Allocation depends on the connected user or not | 2 | 1126 | November 29, 2021 | |
How to check 5G NR PUSCH CLPC | 0 | 404 | February 3, 2023 | |
Can PUCCH be scheduled on SCC when ULCA is supported? | 1 | 406 | October 31, 2021 |
