Hello Experts,
I have a question regarding the MU-MIMO.
Does the gNB change the RI of a UE from 4 to 2 if the conditions are met for pairing?
If so, does it introduce performance degradation to these UEs for whom RI is reduced to 2.
If not, why?
It may degrade user throughput but it does improve cell throughput.
Also user throughput can be improved since it is scheduled in more TTIs.
For example if use is scheduled with 4 layers every 10th TTI means less throughput than if user is scheduled with 2 layers every 2nd TTI.
Okay.
Let’s consider an example.
In case of SU-MIMO, If let say there are 4 UEs and each will get a maximum of 400 DL grants per sec with say RI= 4.
But in case of MU-MIMO, it is possible to get 1600 DL grant per sec by each UE with RI= 2.
So, in this scenario, both the cell throughout and user throughout will increase.
So, can I say MU MIMO is always better than SU MIMO.
