Does transmission backhaul issues can impact BLER as well over air interface?
Not backhaul, but if CPRI Or SFP ports are dirty or faulty then it impacts on high BLER.
Does initial delta cqi helps reduce BLER? | 2 | 434 | July 30, 2021 | |
On 4G what kpis are impacted by transmission? | 1 | 429 | June 10, 2022 | |
Throughput drops with increase in BLER for two NR UEs simultaneously in Lab | 1 | 373 | September 23, 2023 | |
Can we change HARQ settings and what does it depend on? | 1 | 577 | January 18, 2022 | |
5G throughput is degraded with high iBLER / Retransmission in DL | 4 | 1147 | February 10, 2022 | |
Is it possible to see Average UE throughput more than the backhaul of a cell? | 1 | 150 | March 15, 2024 | |
Degradation of bler, throughput and traffic after activating ssb boost power feature | 4 | 556 | February 5, 2023 | |
Throughtput issues due to transmission in LTE | 2 | 1065 | November 29, 2020 | |
TDD UL Synch issue affecting UL Packet and UL BLER | 0 | 340 | October 21, 2022 | |
Sudden drop in 5G DL user throughput while transferring big file | 3 | 381 | June 7, 2023 |
