In case of split bearer, does the UE transmits on LTE and 5G simultaneously with the use of dynamic power sharing?
And does UE has separate antennas for LTE and 5G transmission?
Yes, handset has 4G antenna and 5G antenna.
Dynamic sharing is not mandatory.
Handset would not support it just need to drop LTE side power 3 dB.
Thanks!
Does it happens same while receiving at end of the UE?
I mean UE can connect to a different MIMO mode in LTE and Different MIMO mode in 5G at the same time, to increase the DL throughput perceived by the UE?
