If anyone has implemented Downlink Turbo Pilot Feature please share your thoughts
It’s for MM cells owing to increase cell coverage as MM is capacity based solution.
Overall impact is good but throughput is compromised as allocated power from channels are now being used to boost RS power.
So what’s the suggestion?
We do have high loading as well as spread and distant users.
Go for step by step increase so that you can gauge the best setting for your specific need.
