In UE capability I can see DRX supported.
But not sure why gNB is not sending DRX parameters in RRC_RECONFIG.
From script I have enabled the DRX.
5G VoNR drx parameters | 0 | 498 | August 29, 2023 | |
What are all the possible reasons for which UE does not send Uplink PDN Connectivity Request? | 1 | 563 | November 18, 2022 | |
UE sent 2 RTP packet every 40 ms, is it due to DRX on? | 0 | 415 | June 6, 2021 | |
Alternative methods for UE to read CGI of unknown cell without DRX support in ANR scenarios | 10 | 26 | September 12, 2024 | |
NR SCG addition fails for 'reconfiguration failure' when NR CQI reporting is enabled | 2 | 347 | April 8, 2021 | |
In what conditions network / gNB will not give SRS configuration with "usage- antennaswitching"? | 0 | 113 | March 16, 2024 | |
Packets from UE transmitting towards gNB getting lost | 3 | 413 | June 24, 2022 | |
How can harqmsg3tx value from 5 to 1 improve RRC setup success? | 1 | 503 | March 22, 2022 | |
DRB addition failure | 1 | 776 | October 31, 2021 | |
In what is based the NRFreqBandList reported from eNB to UE in "RRC_UE_CAP_ENQUIRY"? | 0 | 313 | October 30, 2021 |
