E/// PM GPEH parser binary to text
Does anyone have info how to parse/convert ericsson binary gpeh files to readable text format.
Files are collected on ENM in binary format
Thanks,
Boris
@boris, while we hope for someone to share a parser? Can you share the ASN1 spec for the E// GPEH and a sample? I think I can provide some help with this.
Hi dear,
Did you find answer for your question?
